Change jam detection behavior in dev
I'm using jam detection with a microswitch to trigger high when out if filament. It works fine. Bit I don't know that it's out till I look at the printer. Can I modify the gcode so that I can add an m300 to ring the buzzer to alert me somethings going on?
That would be very helpful. Thank you!
Thank you for the consideration!
