"Jam" event dependent gcode
Under repetier fw dev, under mechanics, I have jam detection setup to 1 "show jam out of filament dialog and block communication." This works great. However, when I try option 2 "send pause to the host" it works great too, but I can't do anything since there's no "jam" event type under the printer configuration->gcode->event dependant.
I could use the pause and continue, but this isn't viable as I may want to take other action if filament is out vs a regular pause via the UI.
Just curious if there's a way either in the fw or server to do something specific when a jam happens if using jam_action = 2 in the fw.
Thank you!
