After enabling Distortion Correction, Z moves with X and/or Y.
Hello,
I have a Due/RADDS converted PowerSpec Ultra printer. I have configured the latest Repetier firmware to work with it perfectly. I recently purchased an IR Z probe and have it mounted correctly. In my configuration, I removed the right-most extruder and am only using the left extruder. The z probe is behind the heater block, attached to the belt clip (I designed a belt clip with a mount) and is spaced correctly (the sensors are approximately 1mm above the plane of the nozzle). I can perform the necessary low/high tests and am able to get a measurement of .5mm for trigger. My IR probe is connected to Z-max. There are end stops on X-max, Y-max and Z-min.
I have tried various dimensions for the z probe bed size, but they seem to be ignored. My goal is to have NxN distortion correction for my bed via G33. However, when I enable this feature and install the firmware, homing becomes erratic. The bed would rise, hit the Z-min end stop, and then keep going - or, at least try. I couldn't understand it, until I tried moving the head with G1 commands or Home X/Home Y via S3D. Any command to move X or Y would *also* move Z. So, if the bed was close to Z end stop, it would keep going, trigger the end stop, and continue to try to go through the end stop - because the other dimension (X or Y) hadn't hit its end stop.
I moved the head to the middle of the printer, lowered the bed and tried moving X or Y by a small increment. The bed would move with the G1 X/Y command. I have even tried using another Z-probing section from another post, but the results are the same. For the moment, I have reverted to the non-Z probing configuration.
Does this sound familiar to anyone? Is there a thread similar to this?
