Slic3r freezing windows 10
Repetier host is freezing my laptop when i use Slic3r but not with all prints, the tablet stand gives no problems. When i slice a print it starts slicing and its finishing slicing(i think) In the log i see how much filament is gonna be used and the button "send to server" appears but the same moment the windows is freezing. The computer is not responding and must be forced to power down. When i use Cura with the same print it will finish slicing and i can send it to the server.
System: i5 2550M CPU@ 2.5GHz x64 with 4Gb RAM running windows 10
Tried: Reinstalling (multiple times, with and without admin rights) Repetier Host after uninstall and registry clean, updating Slic3r, renaming registry /HKCU/Software/Repetier from this post and ran sfc /scannow not reporting problems.
Slicing the same prints at different computers(windows 10) with repetier host is not giving any problems.
Any ideas?
Any ideas?
During the slicing it takes around 50MB, total with FF and Comodo running thats 39% total memory usage. The last thing i can read before freezing is repetier is using 2.500MB isn't that a bit much? And why does the rendering go well when using Cura? I sliced the same object with Cura and it takes about 100MB extra when rendering the image.
Cura(working) 114350 lines
Slic3r (freezing laptop) 95166 lines
Slic3r (Other. PC) 129464 lines
So i think its not about the ammount of lines. Cura generates more lines.
How do i remove host and the slicers so really nothing stays behind? I noticed some of my settings are restored after reinstall
Or do you have a better idea?
Reproduced it again this morning, what i did;
Checked the settings again and found a wrong setting, 0.2mm layer height with 150% first layer wont work with a 0.4mm nozzle. So made it .35mm. Tried again.....still freezing.
Took another (old) laptop with host on it, connected it to server, pulled the settings and imported the config.ini from the freezing laptop. So to me it looks like i have 2 identical host installations?
Sliced the same object with the same settings on a old laptop, took a bit longer to slice and rendered the image correctly!
I will send you the STL and my config by mail, let me know if you need more
