how to setup MKS MINI12864LCD
                    Is there anyone know how to setup this LCD with Repetier firmware.
here is the link of the LCD:
https://www.aliexpress.com/store/product/3d-printer-Reprap-LCD-MKS-MINI12864LCD-in-Front-mini-12864-smart-display-Reprapdiscount-controller-Full-Graphic/1047297_32708574939.html
The problem is I do not know what kind of LCD board is this. The LCD has 16 pins only, compare to "RepRapDiscount Full Graphic Smart Controller" has 20 pins.
When I install with Repetier firmware, the background light of screen, the Reset button, the Encoder wheel, SD card present switch, the Buzzer are all working (I believe). But there is no character on the screen.
I wonder what to set in the UICONFIG.H
не удается подключить его. Arduino Due + ПЛАТФОРМЫ-FD Рева. Пробовал прошивки Marlin4Due - Экран работает, но нет связи с SD - картой. Использование дисплея адаптера подключается к контактам 4,74,75,76. Но я не хочу Marlin. Хотите прошивку. У был хороший опыт. Скажи мне что делать? Help
Can't connect it. Arduino Due + RAMPS-FD revA. Tried the firmware Marlin4Due - screen works, but no communication with the SD card. Using a display adapter card is connected to pins 4,74,75,76. But I don't want Marlin. Want your firmware. Have had a good experience. Tell me what to do? Help
