Odd offset move toward Y tower on Delta after homing, but only via host/server connection
When running the host and connected to the server running on the same PC, if I home my delta printer and then manually try to move any direction, it seems to always move about 20mm toward the Y tower every time. After that, any other manual moves work as expected. If I stop the server and connect directly from the host to the printer via USB, the "jog" toward Y doesn't happen; everything moves as expected. Any ideas? Thanks.
-Bill
