Configuration printer plotter. Help
Hi . I am using the .Repetier-Firmware 0.92.9 version with Configuration Tool.
I have the ramps 1.4. And mega arduino.
Below I put the configuration file.
With this confuguracion "it works", I can move the motor in manual control. But the problem is that if I change some parameter of the motor, like speed or steps, then everything remains the same, nothing has changed.
Here and set everything to zero and the engines move. ¿Because ?I do not understand what happens.
xMaxSpeed": 0,
"xHomingSpeed": 0,
"xTravelAcceleration": 0,
"xPrintAcceleration": 0,
"yMaxSpeed": 0,
"yHomingSpeed": 0,
"yTravelAcceleration": 0,
"yPrintAcceleration": 0,
"zMaxSpeed": 0,
"zHomingSpeed": 0,
"zTravelAcceleration": 0,
"zPrintAcceleration": 0,
xMaxSpeed": 0,
"xHomingSpeed": 0,
"yMaxSpeed": 0,
"yHomingSpeed": 0,
"zMaxSpeed": 0,
"zHomingSpeed": 0,
To put a drill, control its speed which driver can be used?
StepsPerTurn / pulley length
