Bl touch folger tech ft-5 diamond hotend upgrade
Hi Guys
Thanks for accepting me in this group
I
need af repetier guru...
Problem:
I bought a Bl touch (non copy Shit)
I have mounted everything like this (except sensor is on Z Max stop...
Before The million dollar question some info:
Machine Folgertech ft-5 diamondhead upgradet
MKS Gen 1.4 board
Running repetier firmware (obvious)
Every thing is solded together an there are no lose ends
Okay does somebody have the configuration h file for a working Bl touch?
Does somebody know how I activate servos1 (gcode)?
PIN Name for det servos1? (not digital pin 11)
Firmware :
http://reprap.me/media/support/firmware/FolgerTech/Repetier-Firmware-Diamond-FT-5.zip
Thank you :-)
Do you have a config h file i can copy and learn from?
regards Rene
