MPX3 board + DMS DP5 printer
Hi, I use MPX3 board and have this issues:
- after using dev version and choosing MPX board, heatbed do not work. When I switch back to 0.9.2.9 it works
- after autoleveling, which works perfect, I cannot print, as head is on new level, cca 3mm above set autolevel (any fw version). Setting slicer or firmware Z correction does not work.
Thanks for any advice.
