PWM values
hi,
is there a possibility to get the PWM values assigned to a variable , not to a Pin?
have some external PWM Controllers running and want to shift the PWM stuff from for example heaters /fans to the external PWM in order to get some Pins free for other functions
can i assign all original pins to one number (so this pin will be not used for hardware)
and use the value from array for updating my external pwm in custom events?
Ok,i will give it a try and see what happens,
as the external PWM Controllers i work with are buyable breakout boards i´ll prepare a template
for Custom Events.
Will share that when finished
