CNC - Features
Hi All,
as I´m interested to improve or add Features for CNC operation of firmware i start this discussion to collect ideas.
please let me know features which are necessary from your point of view or some that just would be "nice to have ".
Thanks for your thoughts
RAyWB
RAyWB
will take a look at that and make a suggestion , may take a few days so i´m busy on other things.
to show spindle speed we would have to implement pwm for cnc , so as mostly all VFC´s are different
we need to set the rpm to pwm range in config.
simple solution is just showing mode or spindle active respectively laser active.
1st. possibility , no placeholder, just show "Laser" or "CNC"
2nd possibility, using M3 / M5 command to show " Laser ON" or "Spindle ON"
3rd possibility, placeholder calculate rpm on PWM setting and show spindle rpm or Laser %
what do you think?
but that´s only one part. Spindles also are different so that´s why i think we need a place in config.h
where we can define a factor for calculation pwm to rpm.
