Share printers between servers
Give the server the ability to share printers other servers on the network. For example: I have multiple printers located far enough from the server it would not be feasible to connect all of them via USB to the server. They are however in range of a network. I could connect the printers to separate servers connected on the same network, share the remote printers with the primary server then I could control them all from one interface.
I am trying to do a simple website using iframes but seems that chrome does not load them, and IExplorer is "protecting" from the use of them. Any suggestion?
But I hope you do not try to run several instances in one page. That might be quite heavy for chrome. Better is to have one iframe with selects and one where you have the active server you currently use.
