G33 not implemented?
The repetier firmware version I am using (0.92.9) has been "tweaked" for the Anet A8 with autolevelling. I went throught the whole process yesterday and it works just fine. But at the end, following this document https://www.repetier.com/documentation/repetier-firmware/z-probing/ it says to issue G33 L0 to get a list of bumps and corrections, but I get an error "unknown command".
Checking repetier.ino, in the comments on top I see that G33 is not listed as part of implemented GCode commands.
So, is it possible for me to change that, and if yes, how do I do that?
Thanks!
Thanks!
