sliced and printed differs
Hi folks!
I've been preparing to print 280*275 hull part
and i discovered unusual behavior mostly on
1 speed changes steeply and suddenly during straight and light curves approach.
2 curves near one of the two corners differ dramatically from what has been sliced
3 skirt is acutually not 100 outside the part and the distance is not even from the part.
please take a look.
settings are basic, is there an info that could help?
Smaller prints are 100% solid run.
which size causes problems i'm figuring out right now.
Advice highly appreciated, thank you, guys!
As for the skirt question. Depending on your slicer, the skirt is created off the bottom layer dimensions. So if your hull starts small and then becomes wider as it goes up, that would be normal to have a skirt that appears smaller than it should.
