server wont start on win vista 64bit
                    reformatted my spare computer and install fresh windows vista 64 bit, trying to install rep server 0.83, gets allmost to the end and then says repetier server has stopped working, so far i have installed java and .net 4, do i need any other periferall software for rep server to run ?
Did it already create a data directory and write something in the log? If not the windows events should show a missing dll on load I guess.
It seems the C++ redist are not completing there installation,gets to about 99% and freezes.
Will need further investigation,maybe motherboard is too old lol
As for the failed installed of the library. Check your system for viruses and malware. Once you are confident that its clean, try turning off anti-virus during the install of the C++ redist. Anti-virus software likes to meddle with installs and cause problems quite often. If that still doesn't allow it to install completely, then you may be facing permission issues or registry issues.
Hope this helps
