Retained History for Reprints
Can you include the option to re-print from History of items that were not saved to server from Host.
Some times I am not sure I want to save the file to server, so I run a direct print job from host. If possible, would like to see a running history of jobs with the option to reprint those that are not saved to server. Also, would expect that a purge after so many days may need to be implemented for those prints as well.
Hope I explained the request good enough... if not, please let me know so I can try and get my thoughts across correctly.
(I am aware of log files, but that looks to be communication info, not historical print data)
Since we also handle small printers like pi powered computer with not very much storage I think it is a waste to store all files printed even if we remove them after a while. As said the model storage should suffice here.
Also, I understand you can re-upload the last sliced file from Host, however its more data to be uploaded again. I realize you all across the pond have way better internet service and speeds. However there are those like myself in the States that run on LTE internet service due to limited availability of high speed data. Also, due to my job, I am unable to always keep the Rep Server on my LAN. So, having an option to not have to upload a file again via WAN would be very beneficial.
Even having the option to re-print the last print from the server would be a great benefit. Or have the option to save the last print on the server to model storage would work. Yes I know I could save to server on every file, but honestly there are times I just plan on printing the single model with no intentions of doing it again. And then something fails or it turns out I need more than a single print.
Please reconsider this as an option in some form or another.
Good news for you is next version accepts zipped gcodes as well. That at least reduces data amount over WAN.
ich fände es auch nützlich wenn man den Aktuellen oder Letzten Druck abspeichern könnte. Wenn man direkt im Repetier-Host auf drucken klickt, ist er nach dem Druck weg, man muss immer drucken und extra speichern. Ab und an Schließt man den Host und denkt sich während dem Druck, das es doch gut gewesen wäre den gcode aufzuheben.
Vielen dank
(sry Chadr619 for german I basicly want the same feature
