Frozen at Turn ON extruder. Connection Problems printing. Not with "Not Extruce" in "Manual Control"
Hello,
I have a lot of problemas with my printer.
I can move in all axis using "Manual Control" but when I turn ON the extruder to start to warm, the printer still frozen. Not move in any axis, not home, not move warm... It happens using connection COM port or Local Server...
I have connections problems when I'm printing. Error: 'Communitation Timeout - reset send buffer block'.
But when I print turning ON the option 'Dry Run' the printer works fine, not communication problems.
I use different USB Cables,
The bauds are the same in the firmaware, Print Settings and COM port.
I reduce the Receiver Cache Size to 63.
Is really frustrating for my, perhaps start a print but in any moment can be frozen or with Error: 'Communitation Timeout - reset send buffer block'.
I use the last RepetierFirmware and Repetier-Host 2.0.1
Can you help me please.
Thanks in advance.
Thanks in advance.
It is what shows the Log Window at connect to the printer:
20:18:39.751 : OpenGL version:4.5.0 NVIDIA 382.05
20:18:39.752 : OpenGL extensions:GL_AMD_multi_draw_indirect ...
20:18:39.756 : OpenGL renderer:GeForce GTX 980/PCIe/SSE2
20:18:39.756 : Using fast VBOs for rendering is possible
20:20:09.599 : Printer reset detected - initalizing
20:20:09.629 : start
20:20:09.630 : Free RAM:3341
20:20:09.646 : SelectExtruder:0
20:20:09.903 : FIRMWARE_NAME:Repetier_0.92.9 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
20:20:09.903 : PrinterMode:FFF
20:20:09.991 : X:0.00 Y:0.00 Z:0.000 E:0.0000
20:20:09.996 : DebugLevel:6
20:20:10.002 : SelectExtruder:0
20:20:10.007 : Unknown command:N7 M20
20:20:10.093 : DebugLevel:6
20:20:10.101 : SelectExtruder:0
20:20:42.068 : X:0.00 Y:0.00 Z:0.000 E:0.0000
20:20:46.366 : X:0.00 Y:0.00 Z:0.000 E:0.0000
20:21:35.939 : X:0.00 Y:0.00 Z:0.000 E:0.0000
You talk about this lines?
When the printer remains frozen is some commands waiting and some times I can't do anything.
Sorry I don't understand that you say:
'Also it might reset when that happens - you should then see a "start" in log appear.'
How?
Sorry about my unknowledge... :-(
