Extruder motor never stop after pause and change filament
I am not sure whether this is a bug but I believe it is.
For many time when I pause the printing,then change filament use the
Quick setting->change filament command,the extruder motor never stop and keep on pushing the filament out,what I can do is to restart the machine,hope somebody could tell me what happened,many thanks
The retracts are run at the beginning. Maybe you have a big value there.
all default numbers
and when I changed filament right after started up the printer but not after pause ,it worked with no problem.
Which firmware version? Always try first upgrading to dev with errors as this is the only version that will receive corrections.
