Remove layers from g-code
                    Hi all, new to Repetier but fairly experienced with 3D printers in general.
Repetier-Host was provided by my printer manufacturer (MP Select Mini). I would like to use it to edit a g-code file that was provided by a supplier. The g-code includes a raft and I would like to print the object without the raft. Is there a quick / easy way to remove the first several layers from a g-code file using Repetier-Host?
I see the ability to edit the code, and I'm fairly confident in doing so, but I also notice there is a z-height associated with each layer. I fear that if I simply delete the lines of code pertaining to the first few layers the z-height for the remaining layers will be too high. Is there a script or something that will do this for me and recursively alter the z-heights for the remaining layers? Maybe there's an even easier way using a function in RH or something?
Alternatively would it be possible to use Repetier to view the speed, layer, shell, etc settings for the provided g-code?
I could simply obtain the model and replicate their output without raft checked on Cura.
