Heated bed temp drops when print starts
                    Hi there,
I have been using my printer to print PLA fine and it works well, with my heated bed at 50 degrees and extruder at 210 degrees.
I am now trying to print in TPE, and so have upped the bed temp to 70 degrees and the extruder temp to 250. Before the print starts, i can use repetier host to set both of these temperatures at the same time and both heat up together to the right temperature. However, when i start printing, the heated bed gradually starts dropping temperature and doesn't go back up.
I am using bang-bang for the heated bed and PID for the extruder.
Any ideas?
Thanks,
Tom.
Any ideas?
Thanks,
Tom.
Is Bed heater on the whole time when Temperature drops?
Im seeing how hot i can get the bed now. Yes its always targeting 70 degrees during print
it got to 88 degrees without the hotend on
Shall i change them over?
What is the -12V 0.8A rail for?
so if you see, you just can get 88 Degrees without Hotend on and without motors on... think that´s the reason.
Maybe you can do another measurement with all switched on and motors running, then i think voltage will drop beyond 10V.
From my experience you should change power supply
if its not the ramps 1.4, maybe could it be that ive wired up my psu incorrectly? Ive used the positive and negatives from the CPU power cable coming from the psu
The connector does feel a little hot actually
A common mod for these is to replace with car type fuses or replace the poly fuse with a wire link and fit inline fuses in the power wires.
I see, ive added a fan temporarily over the fuses and am seeing if that helps
lots of people on forums are mentioning mosfet upgrades for the heated bed with a separate board. Maybe i should get one of those?
i guess you have a single wire from PS to each of ramps input terminal.
https://www.amazon.co.uk/Hrph-Printer-Heated-Current-upgrade/dp/B06ZYQN6VQ/ref=sr_1_1?ie=UTF8&qid=1504980727&sr=8-1&keywords=3d+printer+mosfet
