Need help with Auto bed leveling.
Hi there,
I've moved to inductive Z-probe recently and decided to activate auto bed leveling feature. I've spend a day trying to understand and configure it. But no luck. And I really need your help.
Here's what I have:
- Repetier firmware 0.92.9.
- probe offsets are 20/60 (yes, sensor is bg, I had to move it this far, moves with hotend).
- Table dimensions (keeping probe above table) 280*160mm
- ENDSTOP_Z_BACK_ON_HOME 10
- Z_PROBE_BED_DISTANCE 10
- Z_PROBE_HEIGHT 2.2
- BED_LEVELING_METHOD n*n grid, grid size 5, probe pos.1 20/60, probe pos.2 280/60, probe pos.3 20/160.
If I home all axis, keep hotend at 0/0, and try to run G32, hotend hits endstops making mechanics crack. If after homing I move hotend to, i.e. 100/100 (X/Y), than running G32 makes hotend move in probe coordinates 20/60 (which is physically hotend and table 0/0).
Why does it forces hotend to move beyond 0/0 after homing? If I put first probe pos.1 to 0/0, it also tries to break the limits despite of hotend placement.
Another thing I don't understand is:
Having ENDSTOP_Z_BACK_ON_HOME 10 makes print run (tried on dry run) 10mm above the table. Making ENDSTOP_Z_BACK_ON_HOME 0 helps. But with it in 0, I have to manually move Z axis to prevent plastic blob on hotend.
Use homing option z up X Y Z this will open a section in config tool where you can set the X Y coords for z homeing.
setting ENDSTOP_Z_BACK_ON_HOME 10 artifitially moves the Z0 position to 10mm off the endstop trigger point.
Option Z up X,Y, preheat,Z opens XY Homing pos. for Z option. By default those are 999999. But note says - [mm / 999999 = do not change]. So I asume these coords shouldn't be changed?
And for the ENDSTOP_Z_BACK_ON_HOME 10 - how could I make Z axis to drop table 10mm after Z homing without ruining Z0?
homing just send G28
levelling, i like to make sure the sensor is over the bed before it starts ,so i set in button 2
G1 Z10 F700
G1 X30 Y30 F1200
G32
About homing and lifting Z axis a bit (to keep nozzle clean from plastic blob) - is parameter ZHOME_PRE_RAISE_DISTANCE (appeared when I select Z up X,Y, preheat,Z) what I'm looking for?
G28 ends the homing with a move to X0 Y0 Z0
You could use one of the preset buttons and do
G28
G1 Z5
Select a homing order with preheat and set preheat temperature 0. That option also allows setting z homing position which is what you need.
Few more questions:
- Tools-Bed height map makes Host to crash. Runing with 5*5 points. Crushes on about half way done.
- Z_probe_height -1.000. I have inductive probe and alu table. When I try to home Z axis, it crushes into table on first try, but that stops on the correct height. How to prevent this first time probing from breacking my table?:) Looks like it ignores Z_Probe_Height.
