ENABLE THE EEPROM
Hi
I have been trying to enable the eeprom for some
time now with no success.
Background :-
Sunhockey 2015 prusa i3
printer. windows 10 PC. 73 years old and so no training on computers.
 Not knowing how to find the config file
used by the printer I have searched the C: drive and opened all the
configuration.h files found. I have then changed all from
"//#define eeprom settings" and
"//#define eeprom chitchat" to "#define eeprom settings" and
"#define eeprom chitchat" deleting the two slashes.
When I start the printer and press config “firmware eeprom configuration” it is still greyed out.
Any help would be appreciated
The other option is to bite the bullet and download probably either the latest repetier firmware or dare i say it, latest marlin firmware and go thru all the settings and then compile/upload.
Hi Martin
I have been using the printer since 2015 successfully but when calibrating for instance the Esteps are set at 80.5 and should be 96. I have been changing it by the lcd screen each time I switch on. I believe I can avoid this if I change the eeprom.
I have probably 6 copies of the configuration file on my PC, can I use these to upload to the printer, if so how?
Do this only if you know the config file is really for your printer or it will be worse then before if all the settings are wrong!
Sunhokey have sent me -
1 arduino 1.6.6 RAR File
2 Configuration H File
3 Steps for flashing the main board. File folder
4 Marlin File Folder
What do I do with these?
(I would have attached them so you can see but I can't find any way of attaching them.)
