Issues bed levelling
Hi
I'm having issues setting up bed levelling.
I have a Melzi board and so don't have the option of using Z_Max as I don't have a Z_MAX pin. (I have tried changing the Z_MIN pin to Z_Max but I can't figure it out - Have tried changing pin in pins.h, also specifying pin in config.h. with no joy) Any suggestions?
I get the whole Z_MAX argument, I just can't implement it with my board and I don't want to completely change my board.
So if I can't use a Z_MAX endstop, I'm left with either disabling my Z endstop and always G32 as the first thing (which I'm not wanting to do), or figuring a way to use Z min endstop and Z probe together. I feel like I'm nearly there but my issue with disabling the endstop checks is that when I place a G32 my probe/extruder always want to crash into my X min endstop. (I really want a way to have my Z_Min endstop only for homing like in Marlin Firmware) The only way I seem to be able to bypass this issue is to put a 'G1 X50 Y50' into the probing start up scrip to move it away from the X min endstop. but this is not consistently working in combination with a G28. This is why I wanted to try the development firmware, but I'm getting a:
collect2.exe: error: ld returned 1 exit status
Using library SPI at version 1.0 in folder: C:\Users\tpbha\Desktop\arduino-1.8.5-windows\arduino-1.8.5\hardware\arduino\avr\libraries\SPI
exit status 1
Error compiling for board Sanguino.
Any suggestions would be greatly appreciated.
                exit status 1
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
generator: http://www.repetier.com/firmware/v092/
as you expect.
#define MOTHERBOARD 63
#include "pins.h"
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define FAN_THERMO_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define ZAXIS_STEPS_PER_MM 1600
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 100
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 1
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_INTEGRAL_DRIVE_MIN 50
#define EXT0_PID_PGAIN_OR_DEAD_TIME 20.24
#define EXT0_PID_I 1.89
#define EXT0_PID_D 54.23
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 1
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_HEATER_PIN 12
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 245
#define MIN_DEFECT_TEMPERATURE 5
#define MAX_DEFECT_TEMPERATURE 260
// ## Laser configuration ##
automatically disabled.
#define LASER_PIN -1
#define LASER_ON_HIGH 1
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_Z_BACK_ON_HOME 1
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 1
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 1
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 150
#define Y_MAX_LENGTH 150
#define Z_MAX_LENGTH 118
#define X_MIN_POS -6
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 6
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 3
#define HOMING_ORDER HOME_ORDER_ZXYTZ
#define ZHOME_HEAT_ALL 0
#define ZHOME_HEAT_HEIGHT 10
#define ZHOME_X_POS 50
#define ZHOME_Y_POS 70
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 400
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 400
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 400
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 400
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define USE_ADVANCE 0
#define ENABLE_POWER_ON_STARTUP 0
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define PS_ON_PIN -1
#define JSON_OUTPUT 0
Control the servos with
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 47
#define Z_PROBE_Y_OFFSET 4
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 6
#define Z_PROBE_REPETITIONS 5
#define Z_PROBE_HEIGHT -3.29
#define Z_PROBE_START_SCRIPT "G0 X50 Y75 F3000"
#define Z_PROBE_FINISHED_SCRIPT "G28"
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 50
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 135
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 50
#define Z_PROBE_Y3 135
#define BED_LEVELING_METHOD 1
#define BED_LEVELING_GRID_SIZE 3
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 1
#undef SDCARDDETECT
#endif
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 24
#define ADC_KEYPAD_PIN 1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_PRINTER_NAME "STARTT Modified"
#define UI_PRINTER_COMPANY "iMakr.com"
#define UI_ANIMATION 0
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 20
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_DYNAMIC_ENCODER_SPEED 0
#define UI_SET_PRESET_HEATED_BED_TEMP_PLA 70
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA 190
#define UI_SET_PRESET_HEATED_BED_TEMP_ABS 100
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS 240
#define UI_SET_MAX_EXTRUDER_TEMP 255
#define NUM_MOTOR_DRIVERS 0
"editMode": 2,
"processor": 0,
"baudrate": 115200,
"bluetoothSerial": -1,
"bluetoothBaudrate": 115200,
"xStepsPerMM": 100,
"yStepsPerMM": 100,
"zStepsPerMM": 1600,
"xInvert": 0,
"xInvertEnable": 0,
"eepromMode": 1,
"yInvert": 0,
"yInvertEnable": 0,
"zInvert": "1",
"zInvertEnable": "1",
"extruder": [
"id": 0,
"heatManager": 1,
"pidDriveMin": 50,
"pidDriveMax": 230,
"pidMax": 255,
"sensorType": 8,
"sensorPin": "TEMP_0_PIN",
"heaterPin": "HEATER_0_PIN",
"maxFeedrate": 50,
"startFeedrate": 20,
"invert": "0",
"invertEnable": "0",
"acceleration": 5000,
"watchPeriod": 1,
"pidP": 20.24,
"pidI": 1.89,
"pidD": 54.23,
"advanceK": 0,
"advanceL": 0,
"waitRetractTemp": 150,
"waitRetractUnits": 0,
"waitRetract": 0,
"stepsPerMM": 100,
"coolerPin": -1,
"coolerSpeed": 255,
"selectCommands": "",
"deselectCommands": "",
"xOffset": 0,
"yOffset": 0,
"zOffset": 0,
"xOffsetSteps": 0,
"yOffsetSteps": 0,
"zOffsetSteps": 0,
"stepper": {
"name": "Extruder 0",
"step": "ORIG_E0_STEP_PIN",
"dir": "ORIG_E0_DIR_PIN",
"advanceBacklashSteps": 0,
"decoupleTestPeriod": 12,
"jamPin": -1,
"jamPullup": "0",
"mirror": "0",
"invert2": "0",
"stepper2": {
"uiLanguage": 0,
"uiController": 0,
"xMinEndstop": 1,
"yMinEndstop": 1,
"zMinEndstop": 4,
"xMaxEndstop": 0,
"yMaxEndstop": 0,
"zMaxEndstop": 0,
"motherboard": 63,
"driveSystem": 0,
"xMaxSpeed": 200,
"xHomingSpeed": 40,
"xTravelAcceleration": 400,
"xPrintAcceleration": 400,
"yMaxSpeed": 200,
"yHomingSpeed": 40,
"yTravelAcceleration": 400,
"yPrintAcceleration": 400,
"zMaxSpeed": 6,
"zHomingSpeed": 3,
"zTravelAcceleration": 100,
"zPrintAcceleration": 100,
"xMotor": {
"name": "X motor",
"step": "ORIG_X_STEP_PIN",
"dir": "ORIG_X_DIR_PIN",
"enable": "ORIG_X_ENABLE_PIN"
"yMotor": {
"name": "Y motor",
"step": "ORIG_Y_STEP_PIN",
"dir": "ORIG_Y_DIR_PIN",
"enable": "ORIG_Y_ENABLE_PIN"
"zMotor": {
"name": "Z motor",
"step": "ORIG_Z_STEP_PIN",
"dir": "ORIG_Z_DIR_PIN",
"enable": "ORIG_Z_ENABLE_PIN"
"enableBacklash": "0",
"backlashX": 0,
"backlashY": 0,
"backlashZ": 0,
"stepperInactiveTime": 360,
"maxInactiveTime": 0,
"xMinPos": -6,
"yMinPos": 0,
"zMinPos": 0,
"xLength": 150,
"yLength": 150,
"zLength": 118,
"alwaysCheckEndstops": "1",
"disableX": "0",
"disableY": "0",
"disableZ": "0",
"disableE": "0",
"xHomeDir": "-1",
"yHomeDir": "-1",
"zHomeDir": "-1",
"xEndstopBack": 1,
"yEndstopBack": 1,
"zEndstopBack": 0,
"deltaDiagonalRod": 445,
"deltaAlphaA": 210,
"deltaAlphaB": 330,
"deltaAlphaC": 90,
"deltaDiagonalCorrA": 0,
"deltaDiagonalCorrB": 0,
"deltaDiagonalCorrC": 0,
"deltaMaxRadius": 150,
"deltaRadiusCorrA": 0,
"deltaRadiusCorrB": 0,
"deltaRadiusCorrC": 0,
"deltaXOffsetSteps": 0,
"deltaYOffsetSteps": 0,
"deltaZOffsetSteps": 0,
"deltaSegmentsPerLine": 24,
"stepperHighDelay": 0,
"directionDelay": 0,
"allowQuadstepping": "1",
"doubleStepDelay": 0,
"maxJerk": 20,
"maxZJerk": 0.3,
"moveCacheSize": 16,
"moveCacheLow": 10,
"lowTicksPerMove": 250000,
"enablePowerOnStartup": "0",
"echoOnExecute": "1",
"sendWaits": "1",
"ackWithLineNumber": "1",
"killMethod": 1,
"useAdvance": "0",
"useQuadraticAdvance": "0",
"powerInverting": 0,
"mirrorX": 0,
"mirrorXMotor": {
"name": "Extruder 1",
"step": "ORIG_E1_STEP_PIN",
"dir": "ORIG_E1_DIR_PIN",
"mirrorY": 0,
"mirrorYMotor": {
"mirrorZ": "0",
"mirrorZMotor": {
"mirrorZ3": "0",
"mirrorZ3Motor": {
"name": "Extruder 2",
"step": "ORIG_E2_STEP_PIN",
"dir": "ORIG_E2_DIR_PIN",
"dittoPrinting": "0",
"featureServos": "0",
"servo0Pin": 11,
"servo1Pin": -1,
"servo2Pin": -1,
"servo3Pin": -1,
"featureWatchdog": "1",
"hasHeatedBed": "1",
"enableZProbing": "1",
"extrudeMaxLength": 160,
"homeOrder": "HOME_ORDER_ZXYTZ",
"featureController": 24,
"uiPrinterName": "STARTT Modified",
"uiPrinterCompany": "iMakr.com",
"uiPagesDuration": 4000,
"uiAnimation": "0",
"uiDisablePageswitch": "1",
"uiAutoReturnAfter": 30000,
"featureKeys": "0",
"uiEncoderSpeed": 1,
"uiReverseEncoder": "0",
"uiKeyBouncetime": 20,
"uiKeyFirstRepeat": 500,
"uiKeyReduceRepeat": 50,
"uiKeyMinRepeat": 50,
"featureBeeper": "0",
"uiPresetBedTempPLA": 70,
"uiPresetBedABS": 100,
"uiPresetExtruderPLA": 190,
"uiPresetExtruderABS": 240,
"uiMinHeatedBed": 30,
"uiMaxHeatedBed": 120,
"uiMinEtxruderTemp": 170,
"uiMaxExtruderTemp": 255,
"uiExtruderFeedrate": 2,
"maxBedTemperature": 120,
"bedSensorType": 14,
"bedSensorPin": "TEMP_1_PIN",
"bedHeaterPin": 12,
"bedHeatManager": 0,
"bedUpdateInterval": 5000,
"bedPidDriveMin": 80,
"bedPidDriveMax": 255,
"bedPidP": 196,
"bedPidI": 33,
"bedPidD": 290,
"bedPidMax": 255,
"bedDecoupleTestPeriod": 300,
"caseLightPin": -1,
"caseLightDefaultOn": "1",
"bedSkipIfWithin": 3,
"gen1T0": 25,
"gen1R0": 100000,
"gen1Beta": 4036,
"gen1MinTemp": -20,
"gen1MaxTemp": 300,
"gen1R1": 0,
"gen1R2": 4700,
"gen2T0": 25,
"gen2R0": 100000,
"gen2Beta": 4036,
"gen2MinTemp": -20,
"gen2MaxTemp": 300,
"gen2R1": 0,
"gen2R2": 4700,
"gen3T0": 25,
"gen3R0": 100000,
"gen3Beta": 4036,
"gen3MinTemp": -20,
"gen3MaxTemp": 300,
"gen3R1": 0,
"gen3R2": 4700,
"userTable0": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable1": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable2": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"tempHysteresis": 0,
"pidControlRange": 20,
"skipM109Within": 2,
"extruderFanCoolTemp": 50,
"minTemp": 150,
"maxTemp": 245,
"minDefectTemp": 5,
"maxDefectTemp": 260,
"arcSupport": "1",
"forceChecksum": "0",
"sdExtendedDir": "1",
"featureFanControl": "1",
"fanPin": "ORIG_FAN_PIN",
"featureFan2Control": "0",
"fan2Pin": "ORIG_FAN2_PIN",
"fanThermoPin": -1,
"fanThermoMinPWM": 128,
"fanThermoMaxPWM": 255,
"fanThermoMinTemp": 45,
"fanThermoMaxTemp": 60,
"fanThermoThermistorPin": -1,
"fanThermoThermistorType": 1,
"scalePidToMax": "1",
"zProbeBedDistance": 10,
"zProbePullup": "0",
"zProbeOnHigh": "0",
"zProbeXOffset": 47,
"zProbeYOffset": 4,
"zProbeWaitBeforeTest": "0",
"zProbeSpeed": 2,
"zProbeXYSpeed": 150,
"zProbeHeight": 0,
"zProbeStartScript": "G0 X50 Y75 F3000",
"zProbeFinishedScript": "G28",
"featureAutolevel": "1",
"zProbeX1": 50,
"zProbeY1": 20,
"zProbeX2": 135,
"zProbeY2": 20,
"zProbeX3": 50,
"zProbeY3": 135,
"zProbeSwitchingDistance": 6,
"zProbeRepetitions": 5,
"sdSupport": "1",
"sdCardDetectPin": "ORIG_SDCARDDETECT",
"sdCardDetectInverted": "0",
"uiStartScreenDelay": 1000,
"xEndstopBackMove": 5,
"yEndstopBackMove": 5,
"zEndstopBackMove": 2,
"xEndstopRetestFactor": 3,
"yEndstopRetestFactor": 3,
"zEndstopRetestFactor": 3,
"xMinPin": "ORIG_X_MIN_PIN",
"yMinPin": "ORIG_Y_MIN_PIN",
"zMinPin": "ORIG_Z_MIN_PIN",
"xMaxPin": "ORIG_X_MAX_PIN",
"yMaxPin": "ORIG_Y_MAX_PIN",
"zMaxPin": "ORIG_Z_MAX_PIN",
"deltaHomeOnPower": "0",
"fanBoardPin": -1,
"heaterPWMSpeed": 0,
"featureBabystepping": "1",
"babystepMultiplicator": 1,
"pdmForHeater": "0",
"pdmForCooler": "0",
"psOn": -1,
"mixingExtruder": "0",
"featureAxisComp": "0",
"axisCompTanXY": 0,
"axisCompTanXZ": 0,
"axisCompTanYZ": 0,
"retractOnPause": 2,
"pauseStartCommands": "",
"pauseEndCommands": "",
"distortionCorrection": "0",
"distortionCorrectionR": 100,
"distortionPermanent": "1",
"distortionEndDegrade": 1,
"distortionXMin": 10,
"distortionXMax": 190,
"distortionYMin": 10,
"distortionYMax": 190,
"sdRunOnStop": "",
"featureRetraction": "0",
"autoretractEnabled": "0",
"retractionLength": 3,
"retractionLongLength": 13,
"retractionSpeed": 40,
"retractionZLift": 0,
"retractionUndoSpeed": 20,
"filamentChangeXPos": 0,
"filamentChangeYPos": 0,
"filamentChangeZAdd": 2,
"filamentChangeRehome": 1,
"fanKickstart": 200,
"servo0StartPos": -1,
"servo1StartPos": -1,
"servo2StartPos": -1,
"servo3StartPos": -1,
"uiDynamicEncoderSpeed": "0",
"uiServoControl": 0,
"killIfSensorDefect": "0",
"jamSteps": 220,
"jamSlowdownSteps": 320,
"jamSlowdownTo": 70,
"jamErrorSteps": 500,
"jamMinSteps": 10,
"jamAction": 1,
"primaryPort": 0,
"numMotorDrivers": 0,
"motorDrivers": [
"t": "None",
"s": "",
"invertDirection": "0",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"manualConfig": "",
"zHomeMinTemperature": 0,
"zHomeXPos": 50,
"zHomeYPos": 70,
"zHomeHeatHeight": 10,
"zHomeHeatAll": "0",
"zProbeZOffsetMode": 0,
"zProbeZOffset": 0,
"uiBedCoating": "0",
"langEN": "1",
"langDE": "0",
"langNL": "0",
"langPT": "0",
"langIT": "0",
"langES": "0",
"langFI": "0",
"langSE": "0",
"langFR": "0",
"langCZ": "0",
"langPL": "0",
"langTR": "0",
"accelerationFactorTop": 100,
"bendingCorrectionA": 0,
"bendingCorrectionB": 0,
"bendingCorrectionC": 0,
"supportLaser": "0",
"laserPin": -1,
"laserOnHigh": "1",
"defaultPrinterMode": 0,
"supportCNC": "0",
"cncWaitOnEnable": 300,
"cncWaitOnDisable": 0,
"cncEnablePin": -1,
"cncEnableWith": "1",
"cncDirectionPin": -1,
"cncDirectionCW": "1",
"startupGCode": "",
"jsonOutput": "0",
"bedLevelingMethod": 1,
"bedCorrectionMethod": 0,
"bedLevelingGridSize": 3,
"bedLevelingRepetitions": 5,
"bedMotor1X": 0,
"bedMotor1Y": 0,
"bedMotor2X": 200,
"bedMotor2Y": 0,
"bedMotor3X": 100,
"bedMotor3Y": 200,
"zProbeRequiresHeating": "0",
"zProbeMinTemperature": 150,
"adcKeypadPin": "1",
"sharedExtruderHeater": "0",
"extruderSwitchXYSpeed": 100,
"dualXAxis": "0",
"boardFanSpeed": 255,
"hasMAX6675": false,
"hasMAX31855": false,
"hasGeneric1": false,
"hasGeneric2": false,
"hasGeneric3": false,
"hasUser0": false,
"hasUser1": false,
"hasUser2": false,
"numExtruder": 1,
"version": 92.9,
"primaryPortName": ""
You need a separate pin for z probe. You can use any free digital pin on the board. The endstop pins just have the advantage of having 5V/GND as additional pins so you have power in addition by just using a 3 pin switch, but if you connect power somewhere else it would also work.
off the top of my head i’m Not sure the melzi has any other spare digital pins unless I mess with the LCD connector port (which I don’t want to do.)
thanks
Now to calibrate the Z probe!
MISO/SCK/MOSI can only be used if you do not need them for sd card or other SPI devices, but you seem to have found a free pin, so good job.
Thanks again
1. issue above of once homed planning to move any step in the negative z axis (0.01mm or above) and the hot end automatically lowers to the z Max length but when I send an M114 the z is at 0.0 ( its 0.0 when it’s homed at Z Max) is this normal or is there an issue with my configuration.h?
2. I can do a z probe calibration and then Home and send a G32 S2, and I got it to print once. (Hence I thought success) but when I go to print now, once it’s probed the bed and then homed it lowers to the bed but then goes bellow it causing a crash. I’m confused.
When I go to print I want it to lower to a safe height then move to the bed, not crash into it.
3. When I calibrate the probe, I’ve been doing it in the centre of the bed, is this correct? Or should I do it close to 0,0
Then next question is right z probe height. Autoleveling with that value set wrong can crash into bed at z=0. You can use that as calibration to correct z probe height. Go to Z=10 and then slowly till you hit bottom. Then remaining z is the error in z probe height. So correct and repeat until z=0 is where you need it.
I just can’t seem to calibrate my z probe correctly.
I have followed your instructions both here and the online z probe calibration instructions.
My printer is now doing all movements as it should. I have also physically levelled the bed as best as I can.
I move my hot end to the centre of the bed with G1 X75 Y75 Z5 (so 5mm off the bed)
So ZHold=5.0
Then I send a G30 P0 and get a probing distance of 6.29
So Z0 = 6.29
Then I heat my hot end and bed and remove all excess filament and retract
M114 returns a Zprobe height of 5.0mm
So Z old = 5.0mm (ZHold = Zold)
Then I adjust my nozzle so it touches my metal block of known height (2.1mm)
So Ref Height = 2.1 mm
I send an M114 - Znew= 2.89
This gives me an offset of 2.82
I set this in to my probe height in EEPROM. I ensure my Print bed offsets and dimensions match the printer host but I still get the probe too close to the bed.
G31 tells me my probe is working correctly.
When I go to print I am always too close to the bed by 0.5mm
With baby stepping i can adjust during the first layers and I am 0.5mm too close. However when I then adjust my probe height to account for this in EEPROM I am still too close by 0.5mm. Each time I adjust by the baby stepping amount of 0.5mm off the bed I get closer. (I am homing after each adjustment)
I am now at -0.2mm z probe height (and this can’t be correct even just by eyeballing!
Which is miles off my calibration. I want to calibrate it properly not achieve a probe height by trial and error and even that isn’t working. Where am I going wrong? Please help.
Homing adds extra correction for z homing like bed coating under some configurations. So that can influence result. Also make sure
#define ENDSTOP_Z_BACK_ON_HOME 2
so if it moves xy at top it will not block z by triggering it due to correction. This reduces z length by 2mm. And at the end you can still correct z probe length by the error you have if nothing helps.
My bed coating setting is off (0)
I will check the
My main issue I also need help with was in the previous post which I have inserted here:
‘Hi, sorry I’m still having issues.
So ZHold=5.0
So Z0 = 6.29
Thanks’
Are you doing a new G30 after you have changed the probe height in eeprom
So ZHold=5.0
So Z0 = 6.29
and bed coating tweaked so start height is now good, what does "my layers are still poor" mean? Bed is mainly responsible for first layer and following layer are independent, so what exactly do they look like (photo). Flow rate and temperature and speed are the typical parameters to tweak mid print layer quality.
Can I assume that now the bed levelling has been set up, that the probe is no longer used for the prints unless further adjustment is required. What I mean is that do I need the probe switched on for every print now or can I leave it off until I need to readjust the probing?
Thanks for all you help. Fingers crossed that’s me now.
Results are stored in eeprom so unless you change bed or screws etc no leveling is needed.
I set the Z height both in EEPROM and the host. I also have my bed coating set. The calibration for the z probe height is loaded to EPROM. and all is set.
I then perform a G32 S2
Following completion of homing prior to setting a print, my EEPROM Z Max Hright has changed to a highe value. I have no idea why as I have not personally made any changes. Do you have any suggestions?
Loaded EEPROM/ host Z height 122.77
(Following G32 S2 and then homing- Z Max height in EEPROM = 128.52 ????????????????? Why??
