G or M Code for Flowrate?
is there a G or M Code that will control/vary the flow rate setting in Repetier Host? It would be a welcome function as it would allow users to change flow rates for different layers.
Host also has this as slider if easy mode is disabled. Only requirement is that firmware understands it but nearly all do.
