TTL laser 2W
                    Please, can anybody help me, how to wire & setup ramps 1.4 (mega2560) + repetier.
TTL laser driver:
https://www.aliexpress.com/item/12V-TTL-1W-2W-3W-445nm-450nm-Laser-Diode-LD-Driver-Power-Supply-Stage-Light-lighing/32684581863.html
I have problem with setting intensity, only On+Off works.
I use pin 11,
in Configuration.h I set
I try modify Drivers.cpp
                            TTL laser driver:
I use pin 11,
#define SUPPORT_LASER 1
#define LASER_PIN 11
#define LASER_ON_HIGH 1
#define LASER_PWM_MAX 255
void LaserDriver::changeIntensity(uint8_t newIntensity)
    if(EVENT_SET_LASER(newIntensity))
        // Default implementation
#if LASER_PIN > -1
//        WRITE(LASER_PIN,(LASER_ON_HIGH ? newIntensity > 199 : newIntensity < 200));
        analogWrite(LASER_PIN, newIntensity);
but implementation of this changes is above my options,
it's works in grbl, but I want only one board with 1 code inside for cnc, laser & 3d printer...
