Is it possible to set up homing for the extruder
Hello, I am working with a syringe extruder. When I run out of material
in the syringe I would like to be able to have a "home" position to pull
the syringe plunger back to, for reloading. I already have an endstop
that pauses the printer when the plunger reaches the end of the syringe.
I'd like to have an endstop at the opposite end for unloading.
Is it possible to home an extruder as one would an X, Y, or Z axis?
In your special case you know already you are at the other endstop you could replace homing with a E move of known distance.
