Who is in control - Repetier Host or CURA
                    Hi; I am using Repetier-Host (R-H) 2.0.5 linked to Cura 2.6.1 (latest version for Lubuntu AFAIK). My printer is an ANET A8-L with Skynet/Marlin 2.3.2. My question is; If I change a setting in R-H do I have to change the corresponding setting in Cura as well (and vice versa)?
Thanx
                            Thanx
Parameters like printer dimension, baud rate etc are to be set in host if you print using host.
When I select the 'Slicer' tab and 'configuration' in R-H I am presented with a range of slicer settings options. My question is, if I change any of these settings, do I need to change the corresponding values in Cura, or will the changes I make in R-H over ride the Cura settings?
For server there exists a Cura plugin to upload files from cura 3.1 to server directly.
