Coordinate values in Host
hi, I have maybe little missunderstanding in Repetier Host program. I use MEGA2560+RAMPS1.4. FW0.92.8 + GLCD Smart Controller Display. If I connect board to host and change position of printer by using jogwheel on smart controller, for example new position x=50,y=50, no changes are in coordinates in Host program. If I then use sw manual positioning in software host, printer run back on position 0,0, respectively position maded only by "sw manual positioning". Why? In com port i see strings as "X:50.000 Y50.000 Z0.000 .........." sended into Host program, but no changes in coordinates? Is it right? Thank You for clearing.
We are thinking about reenabling this, also there will be times where it results in wrong values, because then all X: is parsed as x coordinate even if something else was meant.
