apache2 localhost proxy to https domain
Hey guys,
Im trying to setup a secure website via apache2 (first time using it) to my repetier server but with no luck,
this is the config file i use to connect to my repetier server
<IfModule mod_ssl.c>
<VirtualHost *:443>
ServerAdmin webmaster@mydomain.com
ServerName mydomain.com
DocumentRoot /usr/local/Repetier-Server/modules/front/www
# Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
# error, crit, alert, emerg.
# It is also possible to configure the loglevel for particular
# modules, e.g.
#LogLevel info ssl:warn
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
# For most configuration files from conf-available/, which are
# enabled or disabled at a global level, it is possible to
# include a line for only one particular virtual host. For example the
# following line enables the CGI configuration for this host only
# after it has been globally disabled with "a2disconf".
#Include conf-available/serve-cgi-bin.conf
# SSL Engine Switch:
# Enable/Disable SSL for this virtual host.
SSLEngine on
# A self-signed (snakeoil) certificate can be created by installing
# the ssl-cert package. See
# /usr/share/doc/apache2/README.Debian.gz for more info.
# If both key and certificate are stored in the same file, only the
# SSLCertificateFile directive is needed.
SSLCertificateFile /etc/letsencrypt/live/mydomain.com/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/mydomain.com/privkey.pem
# Server Certificate Chain:
# Point SSLCertificateChainFile at a file containing the
# concatenation of PEM encoded CA certificates which form the
# certificate chain for the server certificate. Alternatively
# the referenced file can be the same as SSLCertificateFile
# when the CA certificates are directly appended to the server
# certificate for convinience.
#SSLCertificateChainFile /etc/apache2/ssl.crt/server-ca.crt
# Certificate Authority (CA):
# Set the CA certificate verification path where to find CA
# certificates for client authentication or alternatively one
# huge file containing all of them (file must be PEM encoded)
# Note: Inside SSLCACertificatePath you need hash symlinks
# to point to the certificate files. Use the provided
# Makefile to update the hash symlinks after changes.
#SSLCACertificatePath /etc/ssl/certs/
#SSLCACertificateFile /etc/apache2/ssl.crt/ca-bundle.crt
# Certificate Revocation Lists (CRL):
# Set the CA revocation path where to find CA CRLs for client
# authentication or alternatively one huge file containing all
# of them (file must be PEM encoded)
# Note: Inside SSLCARevocationPath you need hash symlinks
#SSLCARevocationPath /etc/apache2/ssl.crl/
#SSLCARevocationFile /etc/apache2/ssl.crl/ca-bundle.crl
# Client Authentication (Type):
# Client certificate verification type and depth. Types are
# none, optional, require and optional_no_ca. Depth is a
# number which specifies how deeply to verify the certificate
# issuer chain before deciding the certificate is not valid.
#SSLVerifyClient require
# SSL Engine Options:
# Set various options for the SSL engine.
# o FakeBasicAuth:
# Translate the client X.509 into a Basic Authorisation. This means that
# the standard Auth/DBMAuth methods can be used for access control. The
# user name is the `one line' version of the client's X.509 certificate.
# Note that no password is obtained from the user. Every entry in the user
# file needs this password: `xxj31ZMTZzkVA'.
# o ExportCertData:
# This exports two additional environment variables: SSL_CLIENT_CERT and
# SSL_SERVER_CERT. These contain the PEM-encoded certificates of the
# server (always existing) and the client (only existing when client
# authentication is used). This can be used to import the certificates
# into CGI scripts.
# o StdEnvVars:
# This exports the standard SSL/TLS related `SSL_*' environment variables.
# Per default this exportation is switched off for performance reasons,
# because the extraction step is an expensive operation and is usually
# useless for serving static content. So one usually enables the
# exportation for CGI and SSI requests only.
# o OptRenegotiate:
# This enables optimized SSL connection renegotiation handling when SSL
# directives are used in per-directory context.
#SSLOptions +FakeBasicAuth +ExportCertData +StrictRequire
# SSL Protocol Adjustments:
# The safe and default but still SSL/TLS standard compliant shutdown
# approach is that mod_ssl sends the close notify alert but doesn't wait for
# the close notify alert from client. When you need a different shutdown
# approach you can use one of the following variables:
# o ssl-unclean-shutdown:
# This forces an unclean shutdown when the connection is closed, i.e. no
# SSL close notify alert is send or allowed to received. This violates
# the SSL/TLS standard but is needed for some brain-dead browsers. Use
# this when you receive I/O errors because of the standard approach where
# mod_ssl sends the close notify alert.
# o ssl-accurate-shutdown:
# This forces an accurate shutdown when the connection is closed, i.e. a
# SSL close notify alert is send and mod_ssl waits for the close notify
# alert of the client. This is 100% SSL/TLS standard compliant, but in
# practice often causes hanging connections with brain-dead browsers. Use
# this only for browsers where you know that their SSL implementation
# works correctly.
# Notice: Most problems of broken clients are also related to the HTTP
# keep-alive facility, so you usually additionally want to disable
# keep-alive for those clients, too. Use variable "nokeepalive" for this.
# Similarly, one has to force some clients to use HTTP/1.0 to workaround
# their broken HTTP/1.1 implementation. Use variables "downgrade-1.0" and
# "force-response-1.0" for this.
<Proxy *>
Order deny,allow
Allow from all
</Proxy>
ProxyRequests Off
ProxyPreserveHost On
ProxyPass / http://localhost:3344/
ProxyPassReverse / http://localhost:3344/
BrowserMatch "MSIE [2-6]" \
nokeepalive ssl-unclean-shutdown \
downgrade-1.0 force-response-1.0
# MSIE 7 and newer should be able to use keepalive
BrowserMatch "MSIE [17-9]" ssl-unclean-shutdown
SSLCertificateChainFile /etc/letsencrypt/live/mydomain.com/chain.pem
</VirtualHost>
</IfModule>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
now i can connect to the repetier server but some modules cannot be loaded and give a mix contend warning. i tried to use mod wstunnel for apache2 but i get the same kind of errors,
any idea's and suggestions are welcome
Mixed Content: The page at 'https://mydomain.com/' was loaded over HTTPS, but attempted to connect to the insecure WebSocket endpoint 'ws://mydomain.com/socket/?lang=en'. This request has been blocked; this endpoint must be available over WSS.C @ app-min.js?lang=en:2
angular-min.js:2Error: Failed to construct 'WebSocket': An insecure WebSocket connection may not be initiated from a page loaded over HTTPS.
at Error (native)
at Object.<anonymous> (https://mydomain.com/js/app-min.js?lang=en:2:13245)
at Object.i [as invoke] (https://mydomain.com/js/angular-min.js:1:17283)
at Object.$get (https://mydomain.com/js/angular-min.js:1:16227)
at Object.i [as invoke] (https://mydomain.com/js/angular-min.js:1:17250)
at c.instance (https://mydomain.com/js/angular-min.js:2:5187)(anonymous function) @ angular-min.js:2
app-min.js?lang=en:2Mixed Content: The page at 'https://mydomain.com/#/' was loaded over HTTPS, but attempted to connect to the insecure WebSocket endpoint 'ws://mydomain.com/socket/?lang=en'. This request has been blocked; this endpoint must be available over WSS.
They are in js/basics-min.js and js/app-min.js ( 1 each), search for ws:// and replace with wss:// or make it conditional if you still want to connect through http (in your local lan without the virtualhost for example)
I have the same setup running here.
enable mod_proxy_wstunnel
and add
ProxyPass /socket/ ws://localhost:3344/socket/
ProxyPassReverse /socket/ ws://localhost:3344/socket/
before your existing proxy directives (at leasst I have read it has to be before probably because the others are more generic)
and the conditional JS looks like this here:
h=new WebSocket((window.location.protocol == "https:" ? "wss:" : "ws:")+"//"+window.location.host and so on
<VirtualHost *:443>
ServerName YOURHOST.de
ServerAdmin webmaster@YOURHOST.de
LimitRequestBody 102400
SSLEngine on
SSLVerifyClient none
SSLCertificateFile /etc/ssl/certs/YOURHOST.de.crt
SSLCertificateChainFile /home/pi/YOURHOST.de.ca.crt
SSLCertificateKeyFile /etc/ssl/private/YOURHOST.de.key
DocumentRoot /usr/local/Repetier-Server/www/
ProxyRequests Off
<Proxy *>
Order deny,allow
Allow from all
</Proxy>
RewriteEngine on
RewriteCond %{HTTP:UPGRADE} ^WebSocket$ [NC]
RewriteCond %{HTTP:CONNECTION} Upgrade$ [NC]
RewriteRule .* ws://localhost:3344/%{REQUEST_URI} [P]
ProxyPass / http://127.0.0.1:3344/ flushpackets=on
ProxyPassReverse / http://127.0.0.1:3344/
ProxyPass /socket/ ws:///127.0.0.1:3344/socket/ timeout=86400
ProxyPassReverse /socket/ ws://127.0.0.1:3344/socket/
<directory /mod/front/>
Order deny,allow
deny from all
</directory>
<directory /modules/front2/>
Order deny,allow
deny from all
</directory>
</VirtualHost>
SSLEngine on
ProxyRequests Off
RewriteEngine on
</VirtualHost>
apt-getinstallapache2a2enmod ssl proxy proxy_http proxy_wstunnel headers cache rewrite
ps: installed it on Raspberry Pi 3b arm
