dual material Y bowden configuration
Hi all, i'm working on my anycubic kossel for manage dual material with a Y bowden splitter (2 motor, 2 tube, 1 nozzle).
But if a try to configure and setup 2 extruder with 1 mixing color, i loose the option to have different material so i cannot use temperature config different between material....
How i can manage 2 different material in a dual filament print ?
I put in marlin 1.1.8 this 2 change:
#define DUAL_EXTRUDER
clabled 2nd extruder, make some testo with motor move materiale ok.
but.....:
if a put mixing extruder option, seem ok (i did no make a print at moment), in manual control have 1 extruder temp management but i have only 1 filament settings in slicer tab.
also... there is some example of "before extruder switch" and "after extruder switch " somewhere ?
thanks,
Made some other test, find an interesting (and think good ) thing...
configured as 2 extruder NO mixing nozzle:
in manual control, if i put active extruder 1, i can control temperature 1 but not temperature 2
if i put active extruder 2, i can control temperature 2 but not temperature 1...
I think now can be a clear way to use.... but interface is not so friendly... i think better if , when extruder 1 is selected, extruder 2 is gray or similar and viceversa...
