Autoleveling used for PCB
Hello.
I use until one year Repetier for a milling CNC. It work perfectly up tu now
I want to use it to mill some PCB.
I m make some test and the milling of PCB is not working due to the leveling of the copper.
Is it a possibility to use the autoleveling command to correct the leveling and to mill the PCD?
Thanks for your answer
Thierry
y: 50,00 100,42 100,38 100,38 100,39 100,40 100,42 100,43 100,43
y: 37,50 100,42 100,40 100,39 100,40 100,40 100,41 100,43 100,42
y: 25,00 100,42 100,40 100,39 100,40 100,40 100,41 100,42 100,42
y: 12,50 100,43 100,40 100,38 100,39 100,39 100,41 100,44 100,45
y: 0,00 100,42 100,39 100,37 100,37 100,37 100,40 100,45 100,50
01:03:51.819 : Unknown command:N5 M557 X0.00 Y0.00 S10
bed.gif present instead of using the M557 coordinates."Sertenly i use it with a bad configurations
your height map looks quite good. Maybe some distortion in the in the right lower edge.
