Jerk settings
Hi , found that there are changes from 0.92.9 to 1.03 in jerk Settings.
think that´s why i get the message "XY jerk was too low, setting to".
first Point:
is there a reason why
minimumSpeed = accel * sqrt(2.0f / (axisStepsPerMM[X_AXIS]*accel));
changed to
float minimumSpeed = 1.41 * accel * sqrt(2.0f / (axisStepsPerMM[X_AXIS] * accel));
second Point:
i also do not understand why this is added :
if(maxJerk < 2 * minimumSpeed) {// Enforce minimum start speed if target is faster and jerk too low
maxJerk = 2 * minimumSpeed;
Com::printFLN(PSTR("XY jerk was too low, setting to "), maxJerk);
as i´m fighting agaist ringing on my corexy i´m pretty lost on the attempt to reduce jerk while keeping high Speeds and accelerations .
Hope there is some time to explain a Little what´s Happening here.
Change for minimum speed, no idea now. Think that it was a correction for the error at first step. That step has biggest error for low speeds.
All that stuff is really a pain and completely removed in V2. I'm currently working on V2 again. Delta kinematics is now working locally and I will add dual x axis these days. Then all drive systems I plan to support for the start are implemented and I can focus on autoleveling and jam detect to have the important features all working. CoreXY should already work but if it is for your laser system it is not ready.
OK, thanks
I´ll just check out what happens in my System when changing that part back to the 0.92 stuff.
but may be I just touch some physical Limits on my Printer ;-)
(kinematics can go up to 900 mm/s @ acceleration 12000 )
just checking whats "makeable" but think the high weight of idlers and bearings causes that issue
as i´m using 9mm HTD3 belts.
(the GT2 stuff quit the Job after 1200m of Filament , thats the reason for Change to HTD3)
BTW,
is V2 already usable on corexy Printer and can i control it via repetier Server?
so I can give it a try to compare the movement
did some tests, low jerk Settings did not solve my Problem, Problem might be caused by defective linear sliders,
as some balls also quit their Job... (cheap chinese stuff) waiting for new precision rails/sliders now.
I´ll Keep you updated.
Is there something like a Setup guide for the V2 Firmware? (I´m using DUE/RADDS )
https://docfirmwarev2.repetier.com/
Next days there will be a bigger update with delta/dual x axis and many small fixes and additions.
Are you also planning to Support more Hardware ? STM Boards f.e. or Teensy ?
Thanks for the link, think thats enough for me at the moment
OK, but some kind of error handling would be nice on I2C as Errors issue a Watchdog reset.
I have a working one for DUE, will send you a proposal if you are interested
What do you have working for due that you can send me?
