Z axis moving nonstop when printing
                    Here is the issue, my Z axis works just fine when using the manual commands, both the controls and a manual G-code. However, when printing it only moves up, and it doesn't stop.
- I tried inverting the Z axis on repetier host (again, it worked when manually controlling the axis, no difference when printing)
- When homing it was moving up nonstop, so I edited the G-code to delete homing, and the initial Z lift, but any Z position command always makes the Z axis move up to infinity
- The endstop (I only have the MIN) works when manual commands are given, not when printing (it's only moving up, so they wouldn't stop it anyway)
By the way, it was working once upon a time, but I had to format my pc
#define Z_HOME_DIR 1
