Progress bar error withRepetier Host printing
                    The progress bar is not working (comes always back to 0%) if I'm printig via Repetier Host.  If I print via SD the progress bar is working Fine.
Video on 4Shared, bechasuse i can't upload it here. https://www.4shared.com/video/9cP2FK_Rgm/IMG_3857.html
Repetier firmware: 1.0.3
Repetier Host: 2.1.3
Looking into the code it is sending
M532 X<percentage> L<layer>
Can you log it and search for M532 to see what is sending in your case. Maybe it is not using the right format for X so it becomes something like 6,3 also it should use the default . as I did not set a special format there.
I've searched for the code M532. I thing Repetier Host is sending worong the information.
Any idea why repetier Host is doing this?
shall I post a new question in repetier Host forum?
One more question - are you sending directly from host or are you printer over the server. The later case might explain why it goes back to 0. Server would send right values host the wrong as it does not know the percentage. WOuld be an explanation at least.
