RPi server not connecting to Arduino DUE (RADDS)
                    Hi All,
I've got a setup which has been working the past year but I'm upgrading the printer, so a month ago I disconnected everything and wired it all up again.
But right now my RPi 3 does not want to connect to the arduino DUE anymore.
I've tried a new server installation, reuploaded firmware, i also had another due which I tried.
Always the same result.
On the windows PC rep-host it works for a second and then says 1 command waiting.
I also used multiple different usb cables, removed everything so I now only have the Raspberry and the arduino due connected (no radds) but still the same result.
Rep-server does connect to a spare RAMPS 1.4 board I had laying around without issues.
This is a screengrab from the server screen:
And this is the connection log:
< 9:33:44.217: N11 M105
< 9:33:45.226: N12 M105
< 9:33:46.216: N0 M110 N0
< 9:33:46.216: N1 M105
< 9:33:46.216: N2 M115
< 9:33:46.216: N3 M220 S100
< 9:33:46.216: N4 M221 S100
< 9:33:46.216: N5 M355
< 9:33:46.216: N6 G92 E0
< 9:33:46.217: N7 M114
< 9:33:46.217: N8 G90
< 9:33:46.217: N9 M111 S6
< 9:33:46.217: N10 M360
< 9:33:55.233: N11 M105
< 9:33:56.242: N12 M105
< 9:33:57.232: N0 M110 N0
< 9:33:57.232: N1 M105
< 9:33:57.232: N2 M115
< 9:33:57.232: N3 M220 S100
< 9:33:57.232: N4 M221 S100
< 9:33:57.232: N5 M355
< 9:33:57.233: N6 G92 E0
< 9:33:57.233: N7 M114
< 9:33:57.233: N8 G90
< 9:33:57.233: N9 M111 S6
< 9:33:57.233: N10 M360
< 9:34:06.248: N11 M105
< 9:34:07.257: N12 M105
< 9:34:08.246: N0 M110 N0
< 9:34:08.246: N1 M105
< 9:34:08.246: N2 M115
< 9:34:08.247: N3 M220 S100
< 9:34:08.247: N4 M221 S100
< 9:34:08.247: N5 M355
< 9:34:08.247: N6 G92 E0
< 9:34:08.247: N7 M114
< 9:34:08.247: N8 G90
< 9:34:08.247: N9 M111 S6
< 9:34:08.247: N10 M360
Firmware is Repetier 1.0.3
Please help
                Please help
Thanks though
A video of the connection to REP host, with the RADDS on the DUE
PS: Baud rate is correct, I've always used 115200
This is the line sent after the one in the video
So either baud rate is wrong or you are on the wrong serial port of the due (due has 2) but only one normally responds. Server will most likely have same problem.
I reflashed the right baud rate, it's lighting up and the com-port is right. but rep-host just doesn't see it.
Maybe the arduino is broken but i tried another one with the exact same results.
I also tried repetier 0.92.9 but with the same results.
For firmware you could change eeprom mode to ensure it is set to the right value in case something got wrong with the switches.
On one of the boards I did notice that the TX light was burnt, but that one works now as well. Sorry to have kept you busy! Thanks for your time...
