Extruder Heater Activation turns off the printer.
                    Just finished putting a Micro Delta Rework 3D printer together. Installed Repeater host, calibration was smooth sailing until I tried to heat up the extruder.
I can heat up the heat bed no trouble. But every time I click on Extruder Heater Activation, it shuts the printer down.The printer turns back on immediately, and reconnecting to the printer happens without issue. But clicking the extruder heater activation button turns it off again. It's almost as if I had hit the reset button.
It doesn't even give me an error message. Does this happen often? What can I do about it?
Depending on this you can search further. The problem is either firmware using wrong pins for heater or hardware problem like using too much power or creating a short or there is a bridge between an output and something that can trigger reset.
Host is just sending the command "M104 Stemperature".
