Problems connecting by USB
Hi all,
we made our own board based on Arduino Due design (SAM3X8E controller) with TRINAMIC motorcontroller chips.
We would like to connect it by using the native USB port of the controller, but we have a problem connecting to repetier server.
Situation:
- We can connect the board to the PC by USB and install the repetier firmware using Arduino IDE
- At windows device manager the board shows up as "Arduio Due"
- Adding a new printer to repetier server fails because autodetection of baudrate fails
Anyone some ideas ?
Thanks  a lot !
The other thing is that native port connection will not reset the printer, so it will not send the "start" on it's own. That makes the right choice of firmware even more important.
The problem may, in fact, be caused by the Windows Update problem. You can do one thing, i,e, update the Windows and then restart the system. You can also check the Windows status. If it is not satisfactory, then reset the Windows following the steps given on Windows update error code 8007000e and get a better service from the system.
