Lan & usb not detected in server latest image
I have installed repetier server image 0.91.2 on raspberry pi, I am trying to connect LAN cable to raspberry pi but it is not showing the ip address even if i want to import files from usb(pen drives) i am not unable to import it. Suggest the suitable best solution for the same, thanks in advance.
@sapsan The only thing we can control and know about is our server. These issues you talk about are in parts of the linux image. Ok we delivered it with a plugin that years later started to not work and cause problems. But how can we know such a thing? LAN connection is controlled by linux. There is currently not even an option to configure it (also we plan this for a coming release to help here as well). But again is must be our fault that suddenly linux dhcp client is not working? We test on our machine and if it works we publish an image. You test on your machine with your printer and will only offer it when it works there. So we both did not have these problems and had to assume all is fine. Such systems are so complex nowadays with dependencies on clients internet system, routers, ... that it is not possible to control all aspects. All we can do is test and fix what we see and learn and improve as we learn about special problems that maybe just 0,1% will have. Also often the server or even the linux system is not the real problem. Have had many problem reports and often there was an external reason for problems. Just as I said networks from user to printer has many hops and at every point an error can prevent wanted results.
When I installed the older image version & auto-update it everything works fine, the LAN & importing files issue came when I installed fresh 0.91.2 image.
what can we do?
What about importing files through USB? What should I do?
1)installing older image & auto-updating it everything works fine even i can import files through import wizard on LCD.
Case2:
1)installing latest version 0.91.2, but unable to import files because it is showing blank page inside import wizard on LCD.
Even i have checked mount & unmount scripts.
Is there any point am i missing something ?
/lib/systemd/system/udev.service must look like this
# This file is part of systemd.
# systemd is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2.1 of the License, or
# (at your option) any later version.
[Unit]
Description=udev Kernel Device Manager
Documentation=man:systemd-udevd.service(8) man:udev(7)
DefaultDependencies=no
Wants=systemd-udevd-control.socket systemd-udevd-kernel.socket
After=systemd-udevd-control.socket systemd-udevd-kernel.socket systemd-sysusers.service
Before=sysinit.target
ConditionPathIsReadWrite=/sys
[Service]
Type=notify
OOMScoreAdjust=-1000
Sockets=systemd-udevd-control.socket systemd-udevd-kernel.socket
Restart=always
RestartSec=0
ExecStart=/lib/systemd/systemd-udevd
KillMode=mixed
WatchdogSec=3min
TasksMax=infinity
MountFlags=slave
MemoryDenyWriteExecute=yes
RestrictRealtime=yes
RestrictAddressFamilies=AF_UNIX AF_NETLINK AF_INET AF_INET6
MountFlags must be shared ! Then mounting will work after rebootsudo systemctl daemon-reload
after changing the file. After I did that it worked again.
