Repetier "Easel"
I've recently found a CNC tool that appears to be similar to a 3D printer for wood carving. At first glance (I have not studied the product) it seems to use something like Repetier firmware, but a web-based product called "Easel" similar to Repetier Host. I have a home-built printer that was designed to remove the extruder and install a Dremel tool in its place.
It would be nice if there was a software product similar to Repetier Host that could slice and create gcode for wood carving, lathe turning, etc.
