while doing G32, it press on the bed at some points.
I don't know if the Title is clear, but so far I have been unable to solve this.
The first row on the grid (X20), probing is normal.
On the following Rows, for Y20, it continue pressing the head on the bed, (the probe is already on), so the results for these points are wrong (+- 1mm). On the other points, results are looking OK.
When I do Z homing, it looks perfect, the head a coupe of tenth of millimeters above the bed.
I am not sure which parameter I need to change to get proper measures everywhere.
Right now I have Z-Probe Height 4.00, Max-ZProbe bed dist 10.00
Thanks for your help (I Had this working fine before, but I changed the probe and all parameters have to be adjusted)
Z_PROBE_SWITCHING_DISTANCE
make sure this is set high enough to un-trigger the probe , i have mine at 3.
Does the probe return to Z=10 for each point when switching? Normally you should get an error in log if z probe does not switch off where expected. So it will stop when z probe H is detected. If it still gets a bit lower the signal is not coming to the board. Can it depend on the probe type? E.g. inductive probes can be influenced by bed heating or changes in conductive material.
Then test same at a position where you know it measures wrong. See if height is measured differently there. Then you know something is influencing the z probe. Make sure bed is not heating when testing. That is known to influence inductive probes. You also need a metallic surface above the heater or you measure against the heater spirals and they have parts without metal so it influences measurements as well.
Also try repeated G30 to see if probe always measures the same distance so repeatablility is given. If not repeatable, decrease sensitivity so it needs to come closer.
