Extruder diameter change ignored
After replacing my extruder I changed the extruder diameter (under Printer Settings) to the right nozzle aperture diameter; from 0.5 mm to 0.4 mm. I noticed though that the filament wasn't layed down as tight like it used to be. Taking a look at the G-code confirmed what the Print Preview already suggested: there is no difference in generated code for an extruder diameter of 0.4 or 0.5 mm. In fact, there is no difference between 0.27 - 0.53 mm (tested with CuraEngine).I solved this by increasing the filament flow but I don't see the point why the extruder diameter isn't taken into account gradually (or at least every 0.05 mm) when slicing.
