Selective eprom parameters
as i understand, the eprom stores important variables in the firmware without the need of flashing the arduino with new values, but this can lead to a user causing mayhem with the printer. Is there a way to disable the possibility of changing some of the values?
for example, through eprom changes, one can alter the printer size. Can this be disabled and how?
#if DRIVE_SYSTEM != DELTA
// writeFloat(EPR_X_HOMING_FEEDRATE, Com::tEPRXHomingFeedrate);
// writeFloat(EPR_Y_HOMING_FEEDRATE, Com::tEPRYHomingFeedrate);
#endif
// writeFloat(EPR_Z_HOMING_FEEDRATE, Com::tEPRZHomingFeedrate);
writeFloat(EPR_MAX_JERK, Com::tEPRMaxJerk);
writeFloat(EPR_MAX_ZJERK, Com::tEPRMaxZJerk);
#endif
writeFloat(EPR_X_HOME_OFFSET, Com::tEPRXHomePos);
writeFloat(EPR_Y_HOME_OFFSET, Com::tEPRYHomePos);
