Shutdown and Reboot
                    I just installed repetier server on an raspberry pi 3.  I installed raspbian first, then installed armhf variant.  Repetier server is working fine.  I am using the raspberry pi headless, no screen.  Is there a way to shutdown and reboot the raspberry pi within the repetier server web interface? I couldn't seem to locate those options in menus.
See manual advanced setup there is described how to write a extcommands.xml file that adds os commands like shutdown/reboot (that is the example:-) to the menu (gear top right).
