Exclude G-Codes
I slice with Prusaslicer for all of my printing and print on either a Prusa i3 MK2.5S or MK3S
I have had reason to use the exclude g-codes feature from the controls. The excluded region worked as I expected but I found the the adjacent model ended up it the excruder repeatedly over extruding & retracting over the same small area creating a large blob with then cause the print to fail as the nozzle crashed in to it.
I have tested this on both printers with the same result.
