Problem Random operation of the USB connection
Hello,
I still have trouble connecting with the pro server ... This morning, I turn on my prusa MK3 and repetier is working properly and this afternoon, the connection does not seem to work .... Once again, I reinstalled the last image rpi 0.92.2, (why is not there the last image rpi in 0.92.3?) on my side the update in WIFI does not work and crashes as usual. I feel that the USB connection does not work (the rpi port is disabled on the Prusa). I do not know what and I'm a little tired of fighting with unstable versions. what should I do again this time? At startup I have ports that scrolls that did not show up before. What to do to have the USB connection?
I tried to change USB cables, change the USB ports on the RPI ect ...  I specify that when the re-i stallation completes the connection works but if I turn off the printer and the server and then I restart it does not work anymore
Not sure with the flash symbol - normaly it indicates undervoltage but might also signal the overcurrent. Normally dmesg shows undervoltage messages as well.
So unplug all components and reboot and see if the messages go away - might also be something internally connected as usb device.
It's a problem ? You think my rpi is over powered ?
Is it possible to have the latest version 0.92.3 in raspberry image ?
(on the RPi I only have my USB C920 camera connected and the port of the einsy prusa, My 5-inch screen is offset by cables dupont but the screen is powered by this adapter 5V, it can also ask pb ?)
Only thing stange is overcurrent warning. Normally you get undervoltage as said. Overcurrent means the usb device is drawing more then the allowed 500mA. Might be related as well meaning device has not power for the current you draw, but never had that problem so no experience.
My current charger is announced 3A but it comes out 2.8A so I have the logo and the undervoltage warning
Maybe a charger for rpi 4 (5.1V 3A) would fit better for my rpi3B + ?? What do you think ?
https://www.amazon.fr/Aukru-Chargeur-Adaptateur-Alimentation-Raspberry/dp/B01566WOAG/ref=sr_1_25?__mk_fr_FR=%C3%85M%C3%85%C5%BD%C3%95%C3%91&keywords=5v+ac+power+adapter&qid=1571249062&s=electronics&sr=1-25
https://www.amazon.fr/gp/product/B078Y1MSPX/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Now I have no problem booting and I do not have the little yellow logo of undernourishment !
