slicing problem with Cura for dual extruder
After modifying my prusa i3 with the Cyclops dual extruder, and configuring the Repetier firmware, I made my first tests
-Slicing with Slic3r an printing with one color is OK
-Slicing with Slic3r an printing with two color is OK, but dirty so I need wipe towers.
I decided to test Curaengine as I heard it did a great job for the wipe towers.
I configured it as I guess it should be but the slicing gives a weird result, like if the two colors are getting wiped on every layer.
The other problem, if I launch the printing process is that the nozzle heats too much (220° instead of the 180° configured)
Here's a capture of the slicing, I expected to see the same colour in the tower and not alternate colour on each layer
Here's my configuration, if it can help:
I have Geeetech A10T and the only issue I have is making the CureEngine to run custom script per color (the mixing parameters) so I can achieve the color mix properly.
