Random Prints
This issue started after relocating my 3D printer. there are two main issues <span>
</span>
- Repetier Host stops responding abruptly and displays "5 commands pending".
- The part that is being printed does not match with the design. I wanted to print a housing for a sensor, the slicing is perfect but, the printing is printing some random triangle at a corner of build plate.
2. Host prints what you see in preview tab. That are the commands that get send. Could it be that your sliced object is at a position not reachable and what you see are the parts where it comes in reach? Most beds start at 0,0 and got until 2xx, 2xx but if you sliced it around 0,0 only one quarter becomes visible. Other printers have 0,0 in the center of bed.
