Z-Probe-Trigger has no effect on Motor Control
Good morning Repetier-World
I have build a Delta Printer and I'm using Repetier firmware. My Problem is the Z-Probing:
My Z_probe is Connected to the Z_min_Endstop. The Configuration of the Firmware seems to be ok: When I send the G31 G-Code, I got the Message back: Z-Probe state:L. By triggering the Probe by hand and resending G31 I get: Z-Probe state:H. Then I send the G28 -> My Delta homes all three axes, and stops properly at the top of the extrusion. Then I send the G30 G-Code -> The Effector begins to go down in direction of the build-plattform. But when I Trigger the Z-Probe it does NOT stop -> Emergency-Stop. -> Ufffff.
So my basic Question is: Why the Effector doesn't stop moving down, when I push the z-Probe trigger during a G30 Command when the G31 shows a working Z-Probe?
I'm looking now for two Weeks for a solution and I would be very happy if someone is smarter than me ;-).
Greethings from Switzerland
My Z-Probe ist on the Z-Min Pin. I tried several Pins. It was always the Sampe. The G31 Command showed a working Probe, but the Motors didn't ract on the probe trigger during the G30 procedure. In the endstop Configuration all min's are false. In the Z-Probe Configuration the pullup and the inverting is true -> if not -> the G31 Command send a not correct working z_probe status.
My Endstop Configuration (the actual one -> I tried several configurations - always the same picture):
#define ENDSTOP_PULLUP_Y_MIN false
#define ENDSTOP_X_MAX_INVERTING true
#define ENDSTOP_Y_MAX_INVERTING true
#define ENDSTOP_Z_MAX_INVERTING true
Z-Probe Configuration:
#define FEATURE_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 8
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET -8
#define Z_PROBE_Y_OFFSET -17.3
#define Z_PROBE_SPEED 20
#define Z_PROBE_XY_SPEED 100
#define Z_PROBE_SWITCHING_DISTANCE 3
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_HEIGHT 5
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 -121.2
#define Z_PROBE_Y1 -70
#define Z_PROBE_X2 121.2
#define Z_PROBE_Y2 -70
#define Z_PROBE_X3 0
#define Z_PROBE_Y3 140
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
Com::printFLN(PSTR("zprobe hit"));
-> new upload -> Connecting -> G31 -> L -> manual swithcing -> G31 -> H
-> G28 -> wait until homed
-> G30 -> Effector moves down
-> manual Trigger -> nothing happens (The effector continous moving down with homing speed (not with probing speed (20mm/sec)
-> no message on the Display or in the Host
Nearby: when I set: Z_PROBE_WAIT_BEFORE_TEST 0 to true (1) the printer dows not wait for the trigger when i send G30. It start directly with moving down.
Sending a Message (again "Com::printFLN(PSTR("zprobe hit"));") after #if FEATURE_Z_PROBE (after #endif in motion.ccp) chanches nothing on the Display or in the Host (no message).
So when I understand you correctly the Procedure does not enter this Part of Motion.ccp -> how can I change that?
AND: I've got news - I tried something new:
When I send the Command G30 P2 the printer makes a Probe (it sinks with probing speed, trigger works -> Stops the Z-move). G30 P1, G30 P3, G30 does not work (old behaviour). G29 P1-3 dows not work either (continous moving after triggering the z-probe)
After the things I wrote in the last post, I played around with your Idea of Messages. Im motion.ccp I wrote the following:
#if FEATURE_Z_PROBE
if(isZNegativeMove() && Endstops::zProbe())
Com::printFLN(PSTR("zprobe hit1"));
cur->setXMoveFinished();
cur->setYMoveFinished();
cur->setZMoveFinished();
dir = 0;
Printer::stepsRemainingAtZHit = cur->stepsRemaining;
cur->stepsRemaining = 0;
return;
Com::printFLN(PSTR("zprobe hit2"));
#endif
Com::printFLN(PSTR("zprobe hit3"));
I send G30 -> The Effector began to sink with Probe speed and made a Probe and went back home (the FIRST TIME -> Juhuiiiiiiiiiiiii - Sorry for the Swiss Emotions :-) ).
The Display showed during the hole Process nothing new. But the Host showed:
11:37:25.685 : zprobe hit2
11:37:25.685 : zprobe hit3
........ (a lot more)
11:37:26.716 : zprobe hit2
11:37:26.716 : zprobe hit3 -> here I triggered the Probe
11:37:26.716 : zprobe hit1
11:37:26.888 : zprobe hit1
11:37:26.888 : Z-probe:105.56 X:-7.90 Y:-0.01
And now the frustrating thing: It worked for only ONE TIME. The second try showed again the old behavior -> Fast Sinking of the effctor, no effect after triggering the z-probe. (Between these two tries I have not made another Firmware upload. Promised.)
Again when I sent the G30 Command fast descending of the effector and no messages in Display nor in the Host Protocol.
Can you understand that?
Nearby: Thank you very much for your time and help...
Sorry for my late reaction, but it took a lot of work for the following post:
- This Week I tried serveal Pins (X_min, y_min, 42, 44) and it was always the same picture.
- then I chanched the Switch at the end of the Probe (4 Switches, 5 Pins, 2 ways of connecting the switch -> 40 Constellations)
=> always the same picture.
So I doubted the possibility of the double use of the Pin I'm using. When I understood you correctly you still believed it is a hardware Problem. I have a second Printer also with a Ramps 1.4. So I changed the hole Ramps (and Arduino) Module, upload the same Firmware and had a look if it works.
Result: You where right, the Probe works - So it was a hardware problem. It is a little bit frustrating for me, that I probably never will find the mistake. But my second Printer does not use a Probe so I have two working printers again.
I say thank you very much for your time and help and send best regards
Good morning
I got News from the Z-Probing front. I couldn't stay calm, I wanted to know where the Problem Comes from, and I found the solution. We thought that the Problem must be a Hardware Problem. But it was a Software Problem -> EEPROM!!!
In all calibration and tries my Firmware stayed in the EEPROM Modus 1. I changed that value to 2 and reuploaded the Firmware (to the first Ramps/Arduino Module). And suddenly everything went perfect also with the old Ramps/Arduino Module.
So my Theorie is, that something in the EEPROM was no compatible with the new Firmware and I didn't replace that with uploading a new Version by NOT CHANGING the EEPROM value.
I write that, because someone could have the same Problem and it would be my advise to change the EEPROM value in the Configuration.h file.
So i wish good calibration
