Themperature issue
                    Hi all,
running repetier-server fine for months without any issue, right now i have a strange temperature issue, I think a buffer problem but i did not change anything. So, sometime, the print fail at start after heat extruder and bed... for example he said 200 c° but starting in real is a lot of more ( more than 300) so it stop for safety trigger. Some times printing but temperature sways too mutch... like 50 °... I will post 2 pics... For sure you ask me log, just ell me where and how take it correctly thank you
 thank you
 thank you
 thank you
My guess would be a defect thermistor. Strain causes it to report wrong resistances. Can happen. Replace it by identical sensor type and it would be gone normally.
