manual G codes motor does not spin on G1 or G0, does on G28
I use the marlin sofware and a DIY printer.
The motors spin on G28, but not on G1 or G0; Marlin firmware; logging is ok; inside the bed.
any suggestions ?
any suggestions ?
Tried with different max values and both on reptier firmware for the printer and marlin firmware
13:05:47.209 : N12 G28 X0*104 ; G28 manual Home X
13:05:47.834 : ok
13:05:49.162 : N13 G28 Y0*104 ; G28 manual Home Y
13:05:49.771 : ok
13:05:54.099 : N14 G28*38 ; G28 manual Home
13:05:59.271 : ok
13:54:11.700 : N23 G0 X10*97 ; manual is inside max; turns red on the screen if X is outside of X_MAX_POS; no errors in log, no movement
13:54:11.700 : ok
13:54:25.825 : N24 G1 Y20*101 ; manual is inside max; turns red on the screen if Y is outside of Y_MAX_POS; no errors in log, no movement
13:54:25.825 : ok
#define X_MAX_POS 100
#define X_MIN_POS 0
#define Y_MAX_POS 100
#define Y_MIN_POS 0
#define Z_MAX_POS 20
#define Z_MIN_POS 0
Anyhow the moves look legal and should be executed normally. Check with M119 the endstops - if triggered a move in that direction might be blocked. Run M114 before as well to see what firmware thinks where you are. Important for the move direction and hence which end stops would be able to block.
6:18:39.286 : Resend: N36 M119*31
16:18:39.286 : Reporting endstop status
16:18:39.286 : x_min: TRIGGERED
16:18:39.302 : x_max: TRIGGERED
16:18:39.302 : y_min: open
16:18:39.302 : y_max: open
16:18:39.302 : z_min: open
16:18:39.302 : z_max: open
16:18:39.302 : ok
16:19:11.570 : N37 M114*19
16:19:11.570 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
16:19:11.585 : ok
